Failed to create a handle for a linked IPv4 socket
This is an internal socket library issue. Please try the following: check protocol and interface configuration, restart the protocol, reboot the system. If the event still occurs then contact technical support with the output of "show tech".
Error
Failed to create a linked IPv4 socket handle when creating a socket pair. Linked IPv6 socket = %p1% Linked socket type = %p2% Linked socket family = %p3% Linked socket handle = %p4% Application handle = %p5%
| Name | Type |
| p1 | sInt |
| p2 | xInt32 |
| p3 | xInt32 |
| p4 | uInt32 |
| p5 | uInt32 |
